2001 Hyundai Accent Sputtering on Start
2001 HYUNDAI ACCENT
LTTLDUDE9
2001 Hyundai Accent Two Wheel Drive Manual 90000 miles
Thanks for taking time to help me out, I really appreciate your generosity. I have a manual 2001 Hyundai Accent, and when I haven't driven my car for about 12+ hours, and I start it, the car turns on and the engine starts. When I apply the gas pedal the car sputters, or it doesn't even go (almost feels like when you let the clutch up without giving it any gas, the car kind of jumps forward a bit ). When it's not sputtering, it stays in idol even as I push down the gas pedal. This will go on for a couple minutes, and every so often the car will lurch forward as if it's getting gas, but this is only brief and then it goes back to idol/sputtering. After a few minutes of this sputtering, giving it gas, and sometimes having the car turn off completely(stall out), the car will start getting more gas and picking up speed. Once the car starts running, its fine, and drives with no issues. I can even stop and turn off the car, come back an hour later, and it starts perfectly. It's only when it hasn't ran for a 12+ hours. What could be the issue? Any help is greatly appreciated thanks.
Oct 3, 2010 at 6:55 AM
Hi lttldude9, Welcome to 2carpros and TY for the donation
Inspect and test the acceleration sensor, manifold absolute pressure sensor, throttle position sensor and clean the mass airflow sensor with an electronic cleaner CRC
Oct 4, 2010 at 10:27 AM
LTTLDUDE9
Thanks for the feedback. I just replaced the fuel filter and nothing changed. Also I got the check engine light trouble code: P1128 which is Manufacturer Central fuel airmetering valve. Please ntoe this trouble code has been on since I purchase the car (2 years ago), and this has only been a real problem for the past few months, so may be unrelated.
Oct 5, 2010 at 5:25 AM
Try cleaning the mass airflow sensor with an electronic cleaner CRC and see what happens
Oct 5, 2010 at 5:32 AM
LTTLDUDE9
Ok, also just another question. If i check the pressure of the fuel and it is too low, what could that mean? Replace fuel pump?
Thanks
Oct 5, 2010 at 5:34 AM
Could mean the fuel filter, injector and fuel pressure regulator leaking and the fuel pump
Oct 5, 2010 at 5:36 AM
LTTLDUDE9
Ok wow, I wouldn't want to replace all of them if I didn't have to (I have replaced fuel filter). Is there a way I can pinpoint the problem? Does it help to know that the fuel is slow to build pressure in the beginning, but once it's built it drives fine, it's only when it hasn't been driven for 6+ hours is when it has problems.
Thanks, you are helping a ton.
Oct 5, 2010 at 5:51 AM
Check the fuel pressure with a fuel pressure gauge it should be 49.8 psi
Oct 5, 2010 at 5:56 AM
