2001 Hyundai Accent Key Will Not Remove From Ignition
2001 HYUNDAI ACCENT
155,000 MILES • 4 CYL • FWD • AUTOMATIC
AMSM25US
My 2001 Hyundai Accent key will not remove from the ignition. It shuts the vehicle off, but continues to have a power drain on the battery. Once the battery is completely drained of power, and the vehicle will not start, only then can the key be removed completely from the ignition.
Any ideas. Jump starting the vehicle all the time is getting old. Thank you.
Apr 28, 2009 at 4:50 PM
DAVE H
  • 13,384 POSTS
replace the ignition lock barrel !!
Apr 28, 2009 at 4:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty ignition switch, causing key to stick unto power is no longer available to the switch (when battery drains).
Thanks for using 2CarPros.com!
Apr 28, 2009 at 4:55 PM
