2001 Hyundai Accent hard to shift
BCITSHIRTS
Transmission problem
2001 Hyundai Accent 4 cyl Two Wheel Drive Manual
About 2 weeks ago it became harder and harder to shift. We had never had a problem before this, but it's getting worse every day. Help! The clutch doesn't seem to be going out, but what do I know? Someone told me it could be a transmission problem, but someone else said it could be a "transition" problem...making it hard to go from gear to gear. Can I fix this reasonably cheap?
Heather
Nov 19, 2008 at 6:39 AM
KHLOW2008
  • 41,812 POSTS
Hi Heather,
You did not describe the symptoms very clearly so I need to confirm this.
1. Is it easy to shift gears when stationary?
2. Do you have to lift the clutch pedal a lot before the vehicle moves?
3. You mean to say all the gears are difficult to shift into?
4. Any other info that you think can assist?
Nov 29, 2008 at 10:17 PM
