Engine Performance problem
2001 Hyundai Accent 4 cyl Two Wheel Drive Automatic
I have a Hyundaii Accent 2001 with a 1500cc single
cam engine,my problems are these is hard to start cold
iIhave to put the gas pedal to the floor it's shutter
buck for about 1 minute or so and then the idle come on 800rpm or so and there is no power on the engine i can't put it in gear it's stall.I start the engine
again then idle is ok, on the road the transmission is harsh to shift,As soon as the motor is hot those problems are gone.Those problems gradualy worsen over the months.I have change the
2 coil(one was arking),change the fuel pump assembly
the pressure cold was 35psi,change the ISC modulator, clean the MAf.I have tested the injectors with a noid light the 4 have a flash ,sparks on the plug are blue.I have open the Pcm and ne corrosin inside and no loose connectors. Codes of the PCM are all cylinders misfire
300 to 304,p1128 fuel system lean part load and that's it,
Sorry for the english I am from Quebec: a frenchie
Thanks for helping me out
Sep 4, 2010 at 7:16 AM
