2001 Hyundai Accent Check Engine Codes
2001 HYUNDAI ACCENT
DB1965
Engine Performance problem
2001 Hyundai Accent 4 cyl Automatic 53,265 miles
The check engine light came on in my 2001 Accent and then went off. Last night it came on and stayed on, but started flashing. Since last night, it has come on a couple of times, every time flashing. Whenever it flashes, the car starts running rough, like it's not getting enough gas or something. My friend has a code checker (not sure what it's called) and the following codes came on: P0203, P0442, P0300, P0303 and P0301. Is this something I can fix myself? If not, how much should it cost to repair at a shop?? I am a single parent and am watching all of my pennies but I need to have my car fixed correctly.
Jan 29, 2009 at 4:03 PM
CALYPSO93
  • 43 POSTS
Here's a breakdown on the codes,
PO203- Injector #3 circuit malfunction
PO300- Random Misfire
PO301- Cylinder #1 misfire detected
PO303-Cylinder #3 misfire
PO442-Evaporative system small leak detected.
Now from all that, it's obvious that there is a problem with cylinder #3 and #1. I would check the injectors, coils, plugs to ensure they are working. The evap problem relates to the evap purge valve on the charcoal canister.
Jan 30, 2009 at 9:11 PM
