2001 Hyundai Accent Brakes and other parts
2001 HYUNDAI ACCENT
67,000 MILES • 4 CYL • FWD • AUTOMATIC
GFOLKINS
  • 6 POSTS
I was wondering if you could give me a ballpark figure of how many hours of labor it would take a normal, reputable garage to replace the following list of parts?
1. Front left & right upper strut mounts
2. Front left & right strut assemblies
3. Front left & right control arms & bushings
4. Front left & right sway bar links
5. Front left & right tie rod ends
6. Front left & right rotors
7. Front left brake caliper
8. Front left & right brake pads
9. Left parking brake cable
10. Right rear wheel hub assembly
11. Rear left & right brake shoes
12. Rear left & right wheel cylinders
13. Rear left & right brake drums
14. Oil pan
15. Oil pan gasket
16. Valve cover gasket
17. Rear oxygen sensor
18. Windshield wiper linkage (front wipers)
I was told I needed to replace those parts, and I was wondering roughly how long it should take to do a replacement job for those parts.
I want to make sure I have enough money saved up to pay for the labour and any environmental and shop supply fees that may arise.
Thank you
Gerald
Oct 17, 2008 at 9:27 AM
JNOVACK
  • 723 POSTS
was this car in an accedent if so the insurance company should be paying
Oct 17, 2008 at 10:44 AM
GFOLKINS
  • 6 POSTS
No, it wasn't in an accident. They are parts I've let maintenance go. The dealership said those parts needed replacing. People have said not to listen to dealerships because their crooks, but I bought the parts anyway, just to be safe. To my untrained eye, some of the parts look perfectly fine, and I didn't need to purchase them, but I did, just to be on the side of safety.
Oct 17, 2008 at 11:19 AM
JNOVACK
  • 723 POSTS
I would take to another shop and have them check it out seems to much need to be done I don't know were you live but shop labor is usualy between 50-100 per hr plus parts
Oct 17, 2008 at 3:41 PM
GFOLKINS
  • 6 POSTS
I am donating more because I really would like to know if every single part I listed really is in need of replacement, approximately how many hours of labor would I be looking at?
I don't want to estimate myself because I have no clue. If I thought to myself "oh it will take 4 hours, so I will set aside enough money to cover 4 hours of labor" and then come to find out it would actually take 8, I would be out of luck.
I am on a tight budget and just want to know before I put it in anywheres.
Also, if you said 8 hours, and another garage here tells me it would take 15, then that would alert me that maybe that garage is not honest.
That's also why I wanted to know, too.
Thank you
Gerald
Oct 18, 2008 at 2:03 AM
JNOVACK
  • 723 POSTS
all I can tell you is get second oppinion from another shop without inspecting the car my self can't tell you if all those parts realy need replacing but as for time it should take about 8 hrs and about $800-$1000 for labor
Oct 18, 2008 at 2:48 AM
