2001 Hyundai Accent 2001 Hyundai Accent A/C Problem
97,000 MILES • 4 CYL • 2WD • AUTOMATIC
YEPSEE
I had a strange problem. My car would start squealing after I had driven it for 10 miles or so. I took it to a local MIDAS and they changed the A/C belt but the sound didn't go. I again took it back to them and they said they need to replace the whole A/C compressor with clutch which will cost $750. They said that the compressor was stretching the belt which then began squealing. I am a student and I didn't have that much money so as a temporary solution they cut the A/C cable. The squealing sound disappeared.
I am not sure if there recommendation was correct since my A/C is working well and cools the car quickly and efficiently. Was the mechanic taking me for a ride or do I need to burn $750.
Please help.
Mar 16, 2009 at 11:40 AM
ZACKMAN
  • 4,202 POSTS
What do you mean by them cutting the AC cable?
Mar 19, 2009 at 5:03 PM
YEPSEE
They removed the belt that ran the AC so that the compressor didn't run with engine and hence didn't make that sound.
Mar 19, 2009 at 5:13 PM
ZACKMAN
  • 4,202 POSTS
If you can live without the AC, I wouldn't worry about it. But if you have to have the AC, you can probably find a used compressor for cheaper (slightly) and have it installed.
Mar 21, 2009 at 2:34 PM
