2000 Hyundai Accent TRUNK WARNING LIGHT ON DASHBOARD
CARDUMMY81
Electrical problem
2000 Hyundai Accent
hello, my trunk latch is broken but still shuts tight, however the warning light for the trunk door on my dashboard stays on. Im wondering if there is a way for me to disable the light. Any information would be appreciated, thanks.
Aug 29, 2009 at 3:22 AM
SERVICE WRITER
  • 9,123 POSTS
A couple ways. One is to check the trunk switch (green on pic) and see if it can be adjusted. May be part of the latch.
You can pull the fuse (red on pic), but lose your courtesy lights.
OR you can pull out the cluster and remove the bulb.
Aug 29, 2009 at 4:45 AM
