2000 Hyundai Accent Transmission Trouble
48,000 MILES • 4 CYL • 2WD • MANUAL
FELIX9605
I recently got in my car, cranked it, and tried to put it in gear, when, lo and behold, I noticed the gearshift could be moved in a complete circle (as if you were calibrating a computer joystick). In other words, the gear shift does not "slide" into gear. The car runs fine and the clutch is still intact, but I'm not quite sure what is wrong it. Any help is greatly appreciated.
Mar 17, 2008 at 6:00 AM
  • 75,988 POSTS
As per your request in PM Check the select/shift levers-might be loose or disconnected see below
https://images.2carpros.com/forum/automotive_pictures/12900_shift_lever_1.jpg
Mar 19, 2008 at 8:34 AM
