2000 Hyundai Accent rough idle
121,000 MILES • 4 CYL • FWD • MANUAL
TURBOEF
when the car is filled above half a tank it has a rough idle it occasionally stalls but is ok when under half tank. i removed the spark plugs and it appears as if its running rich. any help you can give would be appreciated.
Feb 18, 2008 at 1:11 PM
  • 75,988 POSTS
Have the fuel evaporative system checked-from charcoal canister/purging solenoid all the way to the fuel tank if okay-get the fuel pressure check.
Feb 21, 2008 at 9:31 AM
