2000 Hyundai Accent power booster failure
2000 HYUNDAI ACCENT
130,000 MILES • 4 CYL • FWD • MANUAL
AZEKEA
when I turn on the car's air-conditioner the power booster for the brakes stops working intermitently.
Mar 18, 2010 at 4:27 PM
  • 110,244 POSTS
Have you checked for vacuum leaks to the booster itself?
May 21, 2010 at 3:48 PM
AZEKEA
I have check for leaks to the unit, none found.
I will replace brake booster just to be on the safe side.
May 21, 2010 at 6:52 PM
  • 110,244 POSTS
Before replacing it, to a vacuum test on it to make sure it is bad. THey are not cheap and are a pain to replace. You don't want to do it if you don't need to.
May 22, 2010 at 3:31 PM
