2000 Hyundai Accent Iginition Timing
THE HANDYMAN
Engine Mechanical problem
2000 Hyundai Accent 4 cyl Front Wheel Drive Manual
I just replaced the head on our accent. I made sure to put the timimg marks all on top dead center but I can not get it to run. It sounds like it's way out of time.
Jul 23, 2010 at 1:49 AM
  • 31,937 POSTS
The ignition timing is not adjustable, if the valve timing is correct check that you have the ignition leads in the correct order.
mark (mhpautos)
Jul 23, 2010 at 1:57 AM
