2000 Hyundai Accent i cant fiqure
267,000 MILES • 4 CYL • 2WD • MANUAL
JEREMEY1
hi i have 2000 hyundai accent it idls greet but when driveing it it will bogg and lose power and then go and bogg and lose power again but will sit and idl fine 8 months ago the mass air flow sensor went in it so i unhooked it 8 months ago and ran great till now any ideas whats worng with my car
Mar 9, 2010 at 12:46 PM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 9, 2010 at 11:04 PM
