2000 Hyundai Accent Firing Problems
2000 HYUNDAI ACCENT
JUNIEDOGG
Engine Mechanical problem
2000 Hyundai Accent 4 cyl Two Wheel Drive Automatic
I have a 2000 Hyundai Accent, I cleaned the motor a week ago with engine cleaner and water, now it won't start. I have some firing but not enough to turn the motor. Any suggestions on what the problem might be, some people say it could be the coil pack, but I hate to spend money on something that it might be, any suggestions would be great.
thanks
Jul 25, 2008 at 3:37 AM
DOCFIXIT
  • 18,828 POSTS
Get some electrical contact cleaner and any connection you can get to disconnect and spray
Good luck
Next time consider dry cleaning
Jul 25, 2008 at 4:02 AM
JMOUX088
Chances are when you cleaned it you got water into the holes the spark plugs go into. Check your sparkplugs bud, when the water or solution got into the hole, it could have cracked the sparkplug and it is just crap now. Happened to me a month ago and that was the problem. let it run or drive it around to get the water to dry up
Aug 4, 2008 at 3:07 AM
