2000 Hyundai Accent Engine isn't working right
67,840 MILES • 4 CYL • FWD • AUTOMATIC
COOLJD2002
My car will crank but as it is idling the rpm will go down to about zero and the car will sputter and jerk around. The check engine light will flash when put in drive after idling and it will flash while driving and slow down and not respond to the throttle. The car's gas mileage is drastically less than it is supposed to be. There are brand new spark plugs and spark plug wires on the engine.
Dec 17, 2007 at 7:01 AM
  • 75,988 POSTS
You need to get the OBD2 scanned for codes-you can go to autozone and get a read out and comeback with the codes this is where we start.
Dec 17, 2007 at 7:43 AM
