HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Hyundai
Accent
Engine
Computer
2000 Hyundai Accent ECM
GENE LAWRENCE
MEMBER
2000 HYUNDAI ACCENT
Electrical problem
2000 Hyundai Accent 4 cyl Two Wheel Drive Automatic
Is the eprom inside the ECM
Monday, March 8th, 2010 AT 5:45 PM
MECHANIC
The electronic program read only memory is within the ECM/PCM.
Monday, March 8th, 2010 AT 6:07 PM
GENE LAWRENCE
MEMBER
Thank you for the information
Tuesday, March 9th, 2010 AT 4:36 AM
Please
login
or
register
to post a reply.
Related Engine Computer Content
1999 Hyundai Accent Computer Problem
Computer Problem 1999 Hyundai Accent 4 Cyl Front Wheel Drive Automatic How Can Find The Compute In The The Hyundai Accent. The...
Asked by
Freedy72
1 ANSWER
1999
HYUNDAI ACCENT
GUIDE
Engine Computer
The automotive engine computer, also known as the ECU, PCM or ECM (Engine control unit, Powertrain control module, Engine control module), is central to a vehicle’s ...
Engine Replacement Instructions
I Have Removed Everything That I Know Of To Remove The Engine To My 2006 Hyundai, Using An Engine Hoist, I Still Can't Get The Engine...
Asked by
wilhoite11
39 IMAGES
2006
HYUNDAI ACCENT
2001 Hyundai Accent Cylinder Head
I Put A Cylinder Head In And A New Timing Belt And Now The Car Won't Start It Wants To Start But It Wont
Asked by
tommy29
2001
HYUNDAI ACCENT
1999 Hyundai Accent Busting Of Inlet Manifold
The Inlet Manifold Got Bust And The New One Is Needed So I Want To Know What's The Couse Of It? Couse The Machanic Told Me My Timing Was...
Asked by
nkasa1111
1 ANSWER
1999
HYUNDAI ACCENT
1996 Hyundai Accent Crankshaft Pulley Nut
I'm Trying To Change My Water Pump And Timing Belt. I'm Having Difficulty Undoing The Crankshaft Pulley Bolt. I Have Tried An Impact Wrench...
Asked by
pat191348
1 ANSWER
1996
HYUNDAI ACCENT
VIEW MORE
Engine Computer Symptoms
Oil Change and Filter Dodge Nitro
Throttle Actuator Service
