2000 Hyundai Accent COST OF CLUTCH REPAIR
68,000 MILES • 4 CYL • 2WD • MANUAL
HAWMKE
IT HAS BEEN GETTING MORE DIFFICULT TO SHIFT GEARS ON MY MANUAL CLUTCH, UNTIL TODAY WHEN IT SEEMS ALMOST IMPOSSIBLE TO SHIFT INTO ANY GEAR AT ALL. SEEMS LIKE I MAY NEED COMPLETE REPLACEMENT OR COMPLETE RECONSTRUCTION OF CLUTCH. IF THIS IS TRUE,ABOUT HOW MUCH WOULD REPAIR/REPLACEMENT COST?
Aug 5, 2010 at 7:05 AM
BLUELIGHTNIN6
  • 16,542 POSTS
first check the clutch fluid level. if it's OK then the pressure plate is probably worn and needs replaced. they wear down similar to brake pads over time. on your specific vehicle it takes close to 6 labor hours to replace it, so that is approx. $450 in labor fees alone.
Aug 5, 2010 at 3:50 PM
