2000 Hyundai Accent clutch resevoir
150,000 MILES • 4 CYL • FWD • MANUAL
DREAMS11
fluid wont drain from resevoir to the end of the line when I try to bleed it, the resevoir is full even if i pump the clutch
Jan 6, 2008 at 9:26 AM
  • 31,937 POSTS
HI there,
The bleed screw can get blocked with dirt, remove and check for fluid flow, clean bleeder with very fine probe.
Mark (mhpautos)
Jan 6, 2008 at 9:30 AM
