2000 Hyundai Accent carbon in air lines of gas tank
145,000 MILES • 4 CYL • 2WD • MANUAL
INTOTROUBLE
I am having lots of trouble pumping gas it takes forever. I had my husband pull of the air lines on the gas tank about 4 months ago and tons of carbon bulid up came out . Today we r trying it again cuase the air in the tank shuts off the gas pump every 4 to 5 seconds. We noticed a little box on the other side of the hose. he stuck a rod in there and there is tons of carbon build up probably a pound in there. What is the name of that box? and what could we use to prevent this from happening?
Dec 15, 2008 at 11:05 AM
ZACKMAN
  • 4,202 POSTS
EVAP Charcoal Canister. While you are at it, check your purge valve and purge control solenoid
Dec 17, 2008 at 2:01 PM
