Just repaired head[was warped] new timing belt,car starts and runs smooth but,as soon as you give it gas it stumbles then will rev to where you want in the rpms.I have no vac leaks,coils are fine good fire on sparkplugs,unplugged injs while running pulled off all of them one at a time and runs rough so i know injs are working,new air filter, timing is also perfect......I dont have fuel pressure tester,but it is pushing fuel out nice at the pump+at fuel rail. I would be greatfull for an answer . Thank you
Jul 6, 2008 at 3:37 PM
