when using heat or air it only blows air from the floor or the front window
Jul 15, 2009 at 5:34 AM
✓Experienced Mechanic
The direction vents are actuated by vacuum. My guess is you have a leak. Check under the dask for disconnected or damaged vacuum lines. At times, you may actually hear a hissing sound from a leak if the engine is running.
