Engine Performance problem
1999 Hyundai Accent 4 cyl Front Wheel Drive Manual
Dear Sirs
I need your help for repair my car Hyundai Accent (1300cc year 1999/2000) I was try to repair/ clean the flout Gauge of fuel indicator in the fuel tank but after put in back, a lot of problem come out such as:
1. If I start to heat up the engine in idle stationer, the engine was
unstable/ like clogged up, look like not enough oxygen then after a
few time the engine stop.
2. A/C manual switch not working, the compressor not working…only
the hot air come out from the engine.
3. Washer pump not working anymore. Only the Whiper is working.
I do not know the relation between these problems with the float gauge
that I was take a part, but before that there is not such a problem,
kindly help me to give the explanation/ brightening to solve this problem….
Thank you very much for advise and attention
Regards,
Anita Cahyati
Dear Sirs
Regards,
Anita Cahyati
Apr 26, 2009 at 10:08 PM
