1999 Hyundai Accent car dies when slowing to stop wont rest
LENKERA
1999 Hyundai Accent 4 cyl Manual
when driving down the road car runs good. Coming to a stop or a turn the car will stall and will not restart til after it sits for 30 to 60 mins. Have tried just about everything not sure where to go next.
May 26, 2008 at 9:31 AM
  • 75,988 POSTS
Look for spark and fuel then tell me what's missing. Or you can do below immediately when it acts up.
If the engine's condition is in tip top shape-do below to determine if its fuel or spark problem that's if its cranking over and refuses to start
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
May 26, 2008 at 9:43 AM
