1998 Hyundai Accent fixed loss of power w new plugs and wir
97ACCENT
Transmission problem
1998 Hyundai Accent 4 cyl Front Wheel Drive Automatic 127k miles
Finally fixed my loss of power problem but my transmission does slip and had old fluid in it when i got the car, over 9 months i added a quart of fresh stuff and about 4.5 lucas oil stop slips and it works great....
Last night it lost power but in a different way when i paked it , a pool of tranny fluid under the air filter (which is above tranny) was bubbling and smoking, I know about the pool that built up and would soak it up whenever i had the chance knowing it needs a tranny flush or at least to drain out old fluid
My question, could it simply be the fact that i have waaay to much fluid in and it just bubbled out? once it cooled off its been performing fine i added a little lucas oil stabilizer to it just to keep it lubbed and i would say is vented out almost a quart of excess fluid and im trying to open the drain plug to let the excess fluid out but its on there tight should i start by letting out excess fluid? im afraid to do a full flush...its been known to ruin the tranny all together ive been told, thanks -R
Jul 10, 2009 at 1:35 AM
  • 110,248 POSTS
If you had it over full, then chances are it came out the overflow. As far as a trans service, I have heard the same. I would drain the excess fluid out and see how that works.
Jul 10, 2009 at 2:34 PM
