1997 Hyundai Accent smells and starting
SPIIKE123
  • 1997 HYUNDAI ACCENT
  • V12
  • FWD
  • MANUAL
  • 170,000 MILES
My Hyundai doessn't want to start in the mornings. During the day there is no problem. Why?
Also does it use a lot of oil.
It smells.
Also it smokes in the morning, but after awile it goes away.
What seems to be the problem here for I do not know what to do for I do not knoe much about Hyundai's
Saturday, May 29th, 2010 AT 3:10 AM
Next time it refuse to start hot or cold do below and establish what's missing fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Saturday, May 29th, 2010 AT 11:34 PM
