1997 Hyundai Accent Oxygen Sensor Replacement
19,000 MILES • 4 CYL • FWD • AUTOMATIC
SNERCY83
We wanted to replace our Oxygen sensor ourselves to save us 300.00. It has already been determined that it is the O2 Sensor. I had to ask if it was the front or the back(i read there were two in my car) They informed me "the one in the back." We dont want to mess this up, what can you tell us about replacement? We have a book for our car and it doesnt mention anything about "the back" Im confused. Can you help?
Jan 29, 2009 at 3:09 AM
CALYPSO93
  • 43 POSTS
There is a pre-cat sensor and a post-cat sensor. The precat sensor is before the catalytic converter, usually in the exhaust manifold. You will see this one, when you open the hood and look down at the manifold. should have 3-4 wires coming out of it. The post-cat sensor is after the cat, underneath the car. I'm assuming you read the code, which indicated it was the oxygen sensor? Make sure that there is no leak in the exhaust system ,especially the exhaust flex pipe, it will throw sensors off and make them seem like they are bad. make sure to use penetrating oil on the old sensor, as they are quite difficult to get out. good luck
Jan 30, 2009 at 1:24 PM
