1997 Hyundai Accent No Headlights/No AC at times simutaneou
73,200 MILES • 4 CYL • FWD • AUTOMATIC
UCANA4DIT
No headlights /no AC or fan control at times simutaneously. These are the only two systems that are affected when this happens. I checked every fuse in the fuse panels and the ones under the hood and all seemed ok. Shut the hood down and play with the on/off switches and all of a sudden the headlights and the AC is working again. Never one without the other. When this is happening the Fan does not work. The inside dash lights all work during these episodes but the bright light switch does not. No problems starting the vehicle. Battery nearly new. Did have to jump start after it sat for a few months. What could be causing this?
Jun 4, 2008 at 2:44 PM
KHLOW2008
  • 41,812 POSTS
Hi ucana4dit,
Most probably is a loose connection somewhere. Check underbonnet fuse box connectors under the fuse box.
Jun 5, 2008 at 3:53 AM
