1996 Hyundai Accent Hyundai Accent high oil usage/ engine '
183,000 MILES • 4 CYL • FWD • MANUAL
CARLITO
Hi all! This is a great forum would like to donate but not sure how i have no credit card.
I purchased a 2nd hand Hyundai Accent 1.5 1996 model about a month ago. When i purchased it only real problem i could hear was hole in the 'box' of the exhaust.
I have since had the exhaust fixed, and the car serviced, all was fine except for a really dirty air filter. Since the service the car has the following symptoms:
Starts fine every time
Idling is uneven and not as good as it was when i purchased it.
The car requires about 2 liters of oil a month otherwise it runs too low.
Recently, there has been a 'sucking' noise sound from the engine. The car loses power (when driving about 20km) every now and again, it feels as if it's going to cut out (but hasn't yet)
I was advised to change spark plug wires, which i have, but problem still exists. I fear there may be something dirty inside the engine/ or insiide the fuel injectors.. I have heard 'seafoam' is an option but haven't yet tried that.
Your help would be greatly appreciated
Thanks, Carl
Feb 4, 2009 at 10:15 PM
  • 75,988 POSTS
Get the engine compression check this will tell you the conditions of the valves/rings/cylinders-If there's no leakage anywhere than its being burned in the combustion chamber
Feb 5, 2009 at 1:20 AM
