1996 Hyundai Accent Fuel injector problems
13,200 MILES • 4 CYL • FWD • AUTOMATIC
SSB31
I ran the car earlier in the day, then parked it. An hour later started it up & moved it to do some work, & 15 minutes later it wouldn't start again. I have lots of spark, and the pump is pumping fuel all the way to the injector rail, but the injectors aren't putting gas in the cylinders. I checked the fuses, and they were all good. I'm at a loss as far as why the car stopped.
Jul 26, 2008 at 1:44 AM
KHLOW2008
  • 41,812 POSTS
Hi ssb31,
Get a scan done for DTC and see if it shows anything.
From your symptoms, I would suspect a crankshaft sensor fault.
Aug 16, 2008 at 4:54 PM
BJOUR0
cranksharf sensor fault?? the car would still run.. it has no comon sense with the air/fuel intake if your injestors aren't doing there job its the ECM (computer) of your car thats not sending the signal to the conector on top of the injector.. check with a multimeter if you have some electricity coming from those conectors
your service engine light must be on also.. go get it checked it will probably give you P0201,P0202,P0203,P0204 codes thats a injector circuit malfunction for each cylinder
Ps: youll need to make the car run so take of the plug only once the car is running...
Nov 28, 2008 at 1:53 PM
KHLOW2008
  • 41,812 POSTS
If there is no power supply to the injectors, can you please explain how the engine is going to start?
Nov 28, 2008 at 10:18 PM
