1996 Hyundai Accent
119,623 MILES • 4 CYL • FWD • MANUAL
MICHAELPR
my car star to burn mu fusible of the ignition
i notice that my voltimer mark 16 volt when is star to burn the fusible
i check ground cable of the sound system and alarm but are ok
i disconet both of the system but is till the same problem
Apr 22, 2010 at 1:17 PM
  • 75,988 POSTS
Have the alternator load tested sounds like the voltage regulator is not controlling the alternator output therefore overcharging the battery and can blow fuses due to overvoltages-Could be a short in the ignition system.
Apr 24, 2010 at 3:13 PM
