1995 Hyundai Accent replacing starter
NATBEN
Transmission problem
1995 Hyundai Accent Front Wheel Drive Manual 145000 miles
where is the starter located,diagram please,how to replace
Nov 4, 2010 at 10:25 PM
KHLOW2008
  • 41,812 POSTS
Hi natben, Starter is located at end of battery positive cable. In diagram, the starter bolts are attached to " C " on the transmission, under the manifold.
https://images.2carpros.com/forum/automotive_pictures/192750_Starter95AccentFig01_1.jpg
Sorry I could not find any other diagrams to show you. STARTER Removal & Installation Disconnect negative battery cable. Remove speedometer cable and shift cable. Disconnect starter motor connector and wire. Remove starter. To install, reverse removal procedure.
Nov 4, 2010 at 10:42 PM
