1995 Hyundai Accent Hesitation
1995 HYUNDAI ACCENT
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
LEE MILLER
This car hesitates when warmed up. Replaced plugs,pcv and cleaned throttle body. It hesitates on initial acceleration. OK when cranked up.
Jun 30, 2010 at 2:39 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 30, 2010 at 2:46 PM
