1995 Hyundai Accent
ZACHX
  • 1995 HYUNDAI ACCENT
1995 Hyundai Accent 4 cyl Automatic
Dear Sir,
My car is turning off in traffic.I wait about 2 minutes then I turn it on again. If I dont have possibility to drive quickly( I mean im still stuck in traffic) it will turn off again.I took it to a mechanical, he put it on scanner. He didnt find anything wrong!
SO what might be the reasons, and why only it turns off in TRAFFIC, when im driving on highway everything is fine.
Hope to get a reply soon.
Thank you!
Wednesday, July 1st, 2009 AT 8:20 AM
  • 109,867 POSTS
Did the mechanic check fuel pump pressure?
Thursday, July 2nd, 2009 AT 1:10 PM
ZACHX
He didnt check anything in specific, he put it on scanner, he said it might be several possibilities, but he cant be sure which one is causing probs
Thursday, July 2nd, 2009 AT 3:24 PM
  • 109,867 POSTS
Your mechanic is correct. It could be many things. I would start by checking for vacuum leaks and then check the fuel pump pressure if no vacuum leaks are found. Here is a how to for checking pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
PS: The gauge needed can be rented from many nationally recognized parts stores.
Thursday, July 2nd, 2009 AT 7:28 PM
