Hyper Flashing
2017 NISSAN ALTIMA
18,000 MILES
TAHIRPOLANI
I have installed dual color led front turn signals but they are hyper flashing. I dont want to install resistors but can i replace turn signal flasher or not? i mean if nissan altima 2017 has separate turn signal flasher relay under the steering section or flashing is controlled by BCM? any idea?
Jan 25, 2019 at 8:32 AM
  • 110,244 POSTS
Hi and thanks for using 2carpros.com
The flashing is controlled by the body control module. Be careful making these changes. I have seen damage done to the electrical systems and modules. I would use the OEM type bulb. However, if you want to use the new ones, you will need to install a resister.
Jan 25, 2019 at 10:38 AM
