engine radiator fan
2002 JEEP GRAND CHEROKEE
180,000 MILES • 4.7L • V8 • AWD • AUTOMATIC
JERRY75
My engine fan needs to be replaced. I'm wondering if this is something I can do my self? Where I could find one as cheap as possible? If I can do it my self, a reliable shop that won't charge an arm and a leg? Again this is the hydrolic engine fan, not the radiator fan.
Mar 28, 2016 at 1:44 AM
WRENCHTECH
  • 20,761 POSTS
https://www.2carpros.com/images/external/98608785.jpg.gif The hydraulic fan used on vehicles equipped the 4.7L engine, replaces both the electric fan and the engine driven mechanical fan. The hydraulic cooling fan is integral to the fan shroud and is located between the radiator and the engine. The power steering pump supplies the hydraulic fluid and pressure to rotate the cooling fan blade, while the electrical part of the fan is controlled by the JTEC. The hydraulic fan drive (motor) consists of the three major following components: Steering flow control valve Fan control valve Two stage G-rotor hydraulic drive The hydraulic fan and drive is not serviceable. Therefore any failure of the fan blade, hydraulic fan drive or fan shroud requires replacement of the fan module because the fan blade and hydraulic fan drive are matched and balanced as a system and servicing either separately would disrupt this balance.
Jul 28, 2019 at 5:08 AM
