hydraulic steering leaking
240,000 MILES • 6 CYL • AUTOMATIC
NEIL MYBURGH
  • 5 POSTS
Found that oil is leaking out on the driver side in the front of vehicle. Topped her up and suddenly the steering starts moaning when driving and turning. Leaking somewhere at the pump, spraying it onto the radiator fan. Cup is empty again.
Feb 15, 2017 at 4:22 PM
CARADIODOC
  • 34,415 POSTS
Spraying power steering fluid usually comes from a leaking high-pressure hose. You may need to wash the area with an engine degreaser, then watch where the fluid is leaking from.
Feb 20, 2017 at 10:07 AM
