Hybrid battery problem
2012 TOYOTA CAMRY HYBRID
84,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BEBOBEBO
  • 116 POSTS
Hi, yesterday my car suddenly while driving gave me warning (check hybrid system) and all light on dash turned on, but did not stop. i shut off my car and then restart it but still showed same message. by chance i was near to mechanic garage so he immediately connect it to computer and showed faulty pack battery and he reset the computer car and every thing return to normal. he told me some cells in the battery are falling and weak and advised me to replace it.
Next day i check it again with computer and did not show any codes.
My question is, what is your opinion and advice and how to check the battery function with out taking it out of car? If cells are weak do you suggest I replace battery or replace the cells only?
Thanks.
Mar 27, 2018 at 5:26 AM
SATURNTECH9
  • 30,869 POSTS
If you do have a battery failure within the battery pack the whole pack is replaced as a assembly. I would need to know the exact code numbers not code descriptions not codes descriptions to give you more information.
Mar 27, 2018 at 2:04 PM
BEBOBEBO
  • 116 POSTS
My car gave sign (check hybrid system) and i plugged obd 2 diagnostic and showed code p0A80. To replace hybrid battery pack.
My question, i want change the battery in place around 30 km from my home, is it safe to run my car to this place while?
It is showing this message (check hybrid system). some mechanic told me that the car now depend on fuel engine and it is safe, while others did not advise to run my car in this long distance. what is your opinion?
Thanks
Mar 31, 2018 at 9:52 AM (Merged)
WRENCHTECH
  • 20,761 POSTS
The gas engine should get you there okay.
BEBOBEBO
  • 116 POSTS
Thanx sooo much
Mar 31, 2018 at 10:08 PM
