HVAC temperature blend door not moving after replacing actuator
247,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MCKAYABROWN
  • 21 POSTS
The front HVAC in my vehicle only blows cold air. I've replaced the actuator under the dash on the passenger side of the center console and it doesn't seem to move the blend door at all when I change the temperature on the control panel. I can move the blend door by hand when the actuator is not in place and have verified I'm getting plenty of hot air.
The read HVAC is working fine.
What should I look at next to solve this? I'm getting desperate as this morning was cold and snow (already!) and my feet were frozen by the time I got to work. I included a picture of the control panel in case that helps to see which HVAC I'm dealing with.
Sep 8, 2020 at 2:45 AM
Good afternoon,
Did you calibrate the new actuator?
I posted the procedure below. Give that a try to see if that fixes it.
Actuator Re-calibration
The HVAC control module will relearn the actuator limits whenever power is disconnected and re-connected to the module.
Use the following steps to perform the calibration update:
1. Turn OFF the ignition.
2. Remove the battery positive voltage circuit fuse of the HVAC Control Module.
Important: The scan tool must be disconnected from the vehicle to properly perform the calibration procedure. If a scan tool is connected before this procedure is completed, then new calibration values will not be stored.
Important: Failure to wait 60 seconds will not allow the HVAC control module sufficient time to clear the old calibration values.
3. Wait 60 seconds.
4. Install the fuse.
5. Turn "on" the ignition.
6. Wait 60 seconds before installing a scan tool.
Sep 8, 2020 at 3:50 AM
MCKAYABROWN
  • 21 POSTS
Well, I think I followed the steps. Here's what I did:
Turned off car.
Disconnected the car battery.
Removed the fuse in the picture.
Reconnected battery.
Reinstalled fuse.
Turned car to on position.
I heard actuators moving but there is no change. The blend door still does not open.
Did I pull the right fuse? It's from the box left of the steering column.
Thanks for your help and patience.
Sep 8, 2020 at 12:10 PM
Okay, yes you did.
We need to test the voltages at the actuator to see if it is a wiring issue or a control head issue.
I attached the wiring diagram below.
Sep 8, 2020 at 9:13 PM
MCKAYABROWN
  • 21 POSTS
Roy,
I do have a voltmeter but must admit, I've not used it much. I'm not sure what I am supposed to check or how to use the diagrams you sent. Sorry to be so inexperienced. I appreciate your patience.
Do I need to pull the HVAC controls out of the dash to get the what needs to be tested?
Sep 9, 2020 at 9:57 AM
No, this needs to be done right at the actuator connector.
Sep 9, 2020 at 9:58 AM
MCKAYABROWN
  • 21 POSTS
I removed the actuator and can see that the actuator has moved.
Sep 9, 2020 at 10:15 AM
Does the door it is attached to move freely?
Sep 9, 2020 at 8:49 PM
MCKAYABROWN
  • 21 POSTS
After removing the actuator, I can move the door by rotating the part that was in the actuator. When I move it to the left it provides cold air. When I rotate it to the right I get hot air.
Sep 10, 2020 at 1:29 AM
Okay, when you command heat and cold with the actuator off and the wires connected, does the actuator move or does the motor work in the actuator?
Sep 10, 2020 at 1:34 AM
MCKAYABROWN
  • 21 POSTS
I have not tried that yet. So plug in the actuator and then turn the temperature control. I should have thought of that. I'll try it and get back to you. Thanks.
Sep 10, 2020 at 1:55 AM
You are welcome.
Sep 10, 2020 at 2:23 AM
MCKAYABROWN
  • 21 POSTS
When I plug it in and then turn the car on it only goes one direction. It does not go the opposite. I’m guessing it’s not reacting to The setting but simply to bring plugged in and that the problem is elsewhere. I have nit iced the back lighting on the HVAC controls are only working on half of each dial. Could this be a clue? Could it be a bad control module?
Sep 10, 2020 at 8:45 AM
MCKAYABROWN
  • 21 POSTS
This arrow shows the only direction of travel.
Sep 10, 2020 at 8:49 AM
Yes, this sounds like the control head.
I attached a picture and the procedure for you.
I also attached a picture of the part for you as well.
1. Remove the instrument cluster trim plate bezel.
2. Remove the instrument panel storage tray.
3. Remove the inflatable restraint module switch from the instrument panel. Refer to Inflatable Restraint Instrument Panel Module Replacement in Restraint Systems.
4. Remove the HVAC control assembly.
4.1.Release the retaining tabs.
4.2.Pull the control head out of the instrument panel carrier.
5. Disconnect the electrical connectors from the HVAC control assembly.
Sep 10, 2020 at 9:10 AM
MCKAYABROWN
  • 21 POSTS
I replaced the control module and the lights on it are working. I see now though that the lights on the stereo are now not fully illuminating. And the door does not open even with a new actuator. Any other ideas? Is the stereo an indicator of sorts?
Sep 11, 2020 at 5:18 AM
Okay, you are going to need some help with the voltmeter to do some voltage checks.
Let me know when you are ready.
Sep 11, 2020 at 5:32 AM
MCKAYABROWN
  • 21 POSTS
I’m ready.
Sep 11, 2020 at 5:41 AM
Okay, turn the key to the on position and remove the connector at the actuator.
Check the brown wire for battery voltage.
Sep 11, 2020 at 5:49 AM
MCKAYABROWN
  • 21 POSTS
How exactly do I do that? What setting should I have on the voltmeter? This is how I had it set. When I touch the red probe to the brown wire the volt meter goes to .4 and the drops back to zero.
Sep 11, 2020 at 6:02 AM
Put the setting on 20.
Black lead to a good steel body ground and the red lead to the brown wire.
I posted a guide for you a ways back on how to use a voltmeter. You should take a little time to read the guide.
Sep 11, 2020 at 6:16 AM
MCKAYABROWN
  • 21 POSTS
Thanks for the guide. I also reviewed another online. I supposed my lack of confidence with the voltmeter came through. I also want well grounded even though I though I was. It reads 12.15.
Sep 11, 2020 at 6:25 AM
Okay, the gray wire should have 5 volts. Check that for me.
Sep 11, 2020 at 6:46 AM
MCKAYABROWN
  • 21 POSTS
Here is what I found:
Gray - 5.08
Light blue - 4.3
Gray 0 .04
Blue 4.85
Brown 12.15
Sep 11, 2020 at 7:01 AM
Okay, check the light blue. See if the voltage changes when you command heat and A/C. That voltage should go up and down.
Sep 11, 2020 at 7:06 AM
MCKAYABROWN
  • 21 POSTS
Also, could it be that I simply have the wrong replacement part? The part on the left in the pictures is the one that I pulled out. The right is the one I bought. I did buy the part off Amazon. While Amazon says it's the right part of the vehicle, perhaps it's not what is needed? The picture with the part numbers is the old part. The new part doesn't have any labels the pins appear to be the same - 5 pins with 3 next to each other, a space, and then 2 more pins.
Sep 11, 2020 at 7:09 AM
They seem to be correct.
Sep 11, 2020 at 7:10 AM
MCKAYABROWN
  • 21 POSTS
I tried it with the ignition in the on position and then with the car running. I turned the fan and heat all the way up. Light blue was 4.31 on one reading and 4. 32 on the second.
Sep 11, 2020 at 7:13 AM
What kind of control head did you use? That signal comes from the control head and should change.
Sep 11, 2020 at 7:21 AM
MCKAYABROWN
  • 21 POSTS
I just turned the fan knob to high and the temperature knob to high. I also set the foot as where to direct the heat. If the control head is the HVAC Control Module? that I replaced it's the same as what was there before with a plug that goes into the back.
Sep 11, 2020 at 7:34 AM
If you change to cold, does the voltage change?
Sep 11, 2020 at 7:45 AM
MCKAYABROWN
  • 21 POSTS
No. Nothing changes when I move the temperature selector. it's the same when calling for cold or hot.
Sep 11, 2020 at 7:49 AM
Does the voltage change on the gray or dark blue when you change from cool to hot?
Sep 11, 2020 at 8:46 AM
MCKAYABROWN
  • 21 POSTS
They do not. No change from cold to hot.
Sep 11, 2020 at 9:02 AM
This is all pointing back to the control head itself.
Where did you get this control head?
Sep 11, 2020 at 9:03 AM
MCKAYABROWN
  • 21 POSTS
Local recycled part. Not new. Do these commonly fail?
Sep 11, 2020 at 9:07 AM
Okay, that explains it.
Get a new one.
I attached the part in one of my past posts from Rock Auto.
Sep 11, 2020 at 9:10 AM
MCKAYABROWN
  • 21 POSTS
Thank you for taking so much time to help me.
Sep 11, 2020 at 9:40 AM
No problem.
Glad to help.
Sep 11, 2020 at 11:46 AM
MCKAYABROWN
  • 21 POSTS
Roy,
I'm back! :) I am still chasing down this actuator issue. I purchased a module from Rock Auto and installed it along with a new blend door actuator. The temperature blend door still does not adjust when I adjust the temperature dial on the HVAC control panel in the dash. Any ideas on what else to consider? This did work up until last winter when it simply stopped working. Are there specific fuses or relays? I should look at? I think I pulled and inspected all the fuses. Is there one I should simply replace or would a bad fuse bring the entire control panel offline? Thanks for taking the time to give this some thought.
Nov 20, 2020 at 1:04 AM
