HVAC Solinoid assembly for 1999 Olds Bravada with automatic climate control not manual
81,000 MILES • 3.2L • 6 CYL • AWD • AUTOMATIC
SCALLYT
I saw the post on your web site for a problem with a 2000 olds bravada. In the diagram I can see the correct HVAC Solinoid assembly depicted. I do not see a part # for this item.
When I do an online search for the HVAC solenoid assembly I find model 16171742. This is not the correct part.
Can you help?
Sep 11, 2014 at 5:25 AM
HMAC300
  • 48,601 POSTS
check with a part store for that we only fix them.
Sep 11, 2014 at 11:47 PM
