HVAC re-circulation mode
165,000 MILES • 6.6L • V8 • 4WD • AUTOMATIC
MRACOKER
My re-circulation light comes on but it still pulls air from outside. I need to know the location of the actuator to replace.
Sep 20, 2019 at 6:38 AM
  • 110,246 POSTS
Welcome to 2CarPros.
I attached the directions for removal and replacement. The directions indicate automatic climate control. However, the recirculation actuator is the same as manual. The attached pictures correlate with the directions.
____________________________
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Procedures HVAC System - Automatic Recirculation Actuator
RECIRCULATION ACTUATOR
RECIRCULATION ACTUATOR REPLACEMENT
REMOVAL PROCEDURE
1. Remove the air distribution duct.
pic 1
2. Disconnect the electrical connection from the recirculation actuator (1).
pic 2
3. Remove the recirculation actuator retaining screws.
4. Remove the recirculation actuator.
INSTALLATION PROCEDURE
pic 3
1. Install the recirculation actuator.
2. Install the recirculation actuator retaining screws.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the screws to 1.6 N.m (14 lb in).
pic 4
3. Connect the electrical connector to the recirculation actuator (1).
4. Install the air distribution duct.
__________________________________________________________________________________
Sep 20, 2019 at 1:22 PM
