HVAC Only blows hot air
142,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
M-FERG
HVAC only blows hot air. how to sync blend doors?
Jun 21, 2019 at 8:34 AM
Good evening,
Does the compressor turn on when you command AC? Do you know the pressures?
Procedure
RE-CALIBRATING ACTUATORS
Use the following steps to perform the calibration update:
1. Turn OFF the ignition.
2. Remove the battery positive voltage circuit fuse of the HVAC Control Module.
IMPORTANT: The module memory will not clear if the battery positive voltage circuit fuse is installed in less than 60 seconds.
3. Wait 60 seconds.
4. Install the fuse.
Jun 21, 2019 at 9:13 AM
