Okay, so my vehicle listed above SLT, with 318 magnum engine is having issues with the HVAC only blowing air out of the dash defrost vents and the vent on the back of the center console. The rear roof A/C blows fine as well, but my front and floor vents do not blow air out at all and the defrost vents blow air. I'm thinking constantly even when the HVAC system is totally turned off. And the A/C is not blowing cold anymore, thinking that may be because the front vents are not working, that's what I figure that problem is. I'm pretty sure this vehicle uses the vacuum system and not the electronic one as this is the first generation. I'm pretty knowledgeable on the older vehicles but not sure where to start on this one. How can I fix this and is this why my A/C is not blowing cold? And yes, it's full of Freon and the compressor does engage and run while the A/C is in the on position. Your help would be greatly appreciated. Thank you
May 24, 2022 at 10:47 AM
