HVAC High Setting doesn't work
105,000 MILES
MCALLI27
The blower motor resistor was replaced. The high setting worked for 3 weeks then quit again. It was suggested it was the switch. It was replaced but this didn't fix the problem. High setting still does not work.
Apr 15, 2013 at 6:21 AM
SATURNTECH9
  • 30,869 POSTS
Do you have a multi meter to do some testing?
Apr 15, 2013 at 6:26 AM
MCALLI27
Yes, it will be here in a few days. I have attached the electrical diagram below. It appears as if the High setting doesn't use the resistor, it bypasses it?
Apr 15, 2013 at 7:11 AM
SATURNTECH9
  • 30,869 POSTS
Yes it bypasses the resistor do you have power on the orange wire with the switch in the high position?
Apr 15, 2013 at 11:40 AM
