HVAC dampers do not move
100,000 MILES • 6 CYL • AUTOMATIC
CEASCA7
HVAC dampers stay in one position no matter what is selected. They just blow air out the middle vents - none out the floor and none out the defrost.
Jul 2, 2020 at 8:30 AM
This is most likely the mode door or also called Air vent mode servo motor. This basically changes the position of the door when you select a different position on the control panel.
I included the position of this actuator and here is a guide that will help with this:
Let us know what you find. Thanks
Jul 2, 2020 at 10:00 AM
