HVAC control module installation
51,000 MILES • 3.1L • 6 CYL
SHELBYGT08
  • 11 POSTS
I’m installing a refurbished HVAC control module do I have to match up the settings from the one I am removing to match on the new one or will it automatically move according to the settings on the new one? For example the fan is on low the hot and cold part is on the hottest setting and the other other mode is on defrost.
Dec 2, 2020 at 10:30 AM
  • 110,248 POSTS
According to the directions from prodemand, it is a plug and play set up. There is no indicator for programming and so on.
If you look at the two attached pics, they show directions which are vague, but as mentioned, show no relearn procedure or requirements for presetting the unit.
Dec 2, 2020 at 11:08 AM
SHELBYGT08
  • 11 POSTS
Thanks Joe. I will set the controls the same as the old one just to be safe.
Dec 2, 2020 at 11:22 PM
  • 110,248 POSTS
You are very welcome. If you have a chance, let me know how things turn out for you. Also, feel free to come back in the future if you have questions.
Dec 3, 2020 at 11:59 AM
