HVac control
250,000 MILES • 3.3L • V6 • FWD • AUTOMATIC
ROBCABBIE
Air only comes out at the defrost vents. No change with replacement of control panel or re-calibration of unit.
May 28, 2016 at 9:37 AM
HMAC300
  • 48,601 POSTS
you can try reprogramming but you may have a bad mode door actuator or broken door. to fix the actuator the dash must be pulled. see pictures for calibration since you replaced control panel.
May 29, 2016 at 1:46 AM
