HVac control
250,000 MILES • 3.3L • V6 • FWD • AUTOMATIC
ROBCABBIE
Air only comes out at the defrost vents. No change with replacement of control panel or recalibration of unit.
May 28, 2016 at 9:32 AM
  • 110,248 POSTS
Is there engine vacuum to the control panel? The defroster is the default if there is an issue. If engine vacuum is not getting to the system, the vents cannot change air flow direction.
May 30, 2016 at 12:09 PM
ROBCABBIE
First answer is correct. It's an all day job. Shop charge 3 to 5 hundred labor plus part. Must have skinny hands, very tight space. ????
Jun 6, 2016 at 7:00 AM
  • 55,682 POSTS
It sounds like a blend door actuator is bad on the left side of the heater box, here is a diagram and guide to help you
Let me know what you find
Jun 6, 2016 at 9:36 AM
