How to remove the HVAC blower motor?
135,000 MILES • V8 • 2WD • AUTOMATIC
WORDFLOW
I need description of blower motor removal procedure. A video would be nice. I have removed everything except the motor. I can't get the housing apart.
Jun 13, 2022 at 3:37 AM
Sure. Here are a couple guides that will help with this. The video is of a Ford, but it is going to be similar.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
https://youtu.be/1eau7hCuuJ8
However, the process from the manual is below. Please run through all this info and we can go from there.
Thanks
Jun 13, 2022 at 8:21 AM
WORDFLOW
This information was not helpful, but thanks for the effort.
Jun 14, 2022 at 10:29 AM
Did you see the attached documents that I provided for your specific vehicle? I understand the look is different between the Ford and GM but the idea with the video was to give you the overall process not an exact step by step.
The exact step by step from the manual for this vehicle was attached below my previous post.
Basically, I am trying to give you as much info as possible to help you do this repair. Sorry I don't have a video on your vehicle but unfortunately that is not possible to make a video on every vehicle.
Please review the attached documents and let me know if you have questions. Thanks
Jun 14, 2022 at 11:51 AM
