HVAC blend door replacement instructions/guides needed?
999,988 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DEBORAH LOGAN
What needs to be disassembled to replace the HVAC blend door?
Dec 17, 2023 at 11:40 PM
  • 55,542 POSTS
There are three blend door actuators, mode, inlet and temperature, can I ask which one you mean to replace? Here are all of the locations for each actuator included the mode cam that works with the actuator. These are the instructions for each. Check out the images (below). Let us know if you need anything else.
Dec 18, 2023 at 8:08 AM
DEBORAH LOGAN
#17 blend door
How many hours to replace with a new blend door?
Dec 18, 2023 at 10:10 AM
  • 55,542 POSTS
#17? Our choices are blend door actuators, mode, inlet and temperature. Which one pleases?
Dec 18, 2023 at 10:12 AM
DEBORAH LOGAN
The blend door located by the heater core to blow the air.
Dec 28, 2023 at 4:33 AM
  • 55,542 POSTS
The mode blend door actuator is responsible for the air direction through the vents. Is this the problem you are having?
Dec 29, 2023 at 2:26 AM
