HVAC blend door actuator what is the price on avg to replace?
78,500 MILES • 4 CYL • 2WD • AUTOMATIC
MARSHALL HARTMAN
my vehicle listed above has ticking noise on the driver's side. what is the avg price to replace it, so i know they not over charging me.
Jul 20, 2025 at 6:51 AM
  • 55,688 POSTS
Okay they should charge .8 hours to change it; this is what the book says. So, .8 hrs@ shop labor rate will be the labor charge. The part should be about $22.00 here is one on Amazon:
https://amzn.to/4o5UbAy
Here is the location of the actuator. Check out the images (below). Let us know if you need anything else.
Jul 21, 2025 at 4:13 AM
